adjust valves on a ...
adjust valves on a cold engine
2 Users
(@adt8687)
Eminent Member Registered
can anyone help me with the cold valve settings on my 175 CI 1940 Hudson engine. I know the hot settings are .006 and .008 on the int. and exh. I am putting the engine back together after a rebuild and would like to get the setting as close as possible. thanks in advance for any help.
Posted : 06/03/2016 4:52 pm
(@kevinjets)
Set them cold at .008 and .010. Use new feeler gauges and set at a drag fit. Walt.
Posted : 07/03/2016 4:07 am
(@adt8687)
Thanks Walt I knew I could count on you!!!!
Posted : 07/03/2016 5:54 am
