WTN Index - 1964 th...
WTN Index - 1964 thru May 1976
3 Users
(@35terraplane)
Prominent Member Registered
I recently finished the 1963 thru May 1976 WTN index that Lou Backus produced back in 1976. It will be in the club library (filed under Other H-E-T Literature) when I get around to sending it to Paul and Paul gets around to putting it online.
In the meantime anybody that would like a copy drop me an email at NCEhudsontech09@yahoo.com (drop the NEC).
I'll be working on the one George Schmidt put out covering the early 1980's and I have a copy of Vernon Holt's tech info index I'll be doing sometime in the future.
Hudsonly
Alex b
Posted : 26/02/2016 3:13 pm
(@jairomedina)
As usual Alex thanks for all the hard work you put in on these things; without you the library would not be as impressive an area as it is!
Send it across when you're ready and I promise to get it up straight away 🙂
Posted : 27/02/2016 12:01 am
(@jairomedina)
That is now posted and appears as the number one post in the library top ten 🙂
Posted : 28/02/2016 6:30 am
(@pacemaker52)
Trusted Member Registered
Yes Alex, you have made a wonderful library to go and research pertinent information that has helped me tremedously in restoring my Hudson. Thank you for all your hard work!!
Thank you Paul for your part and time involved too!!
Posted : 29/02/2016 3:56 am
