Stepdown vibration
Stepdown vibration
12 Users
(@m-patterson56)
Rob,
If you raised the car and had only one wheel spinning, the spider gears would be in full function mode, which generates quite a growl since they are spur/bevel gears. This isn't normally heard in ordinary driving cause they are only moving in turns and very slightly all of the time to take up differences in rear wheel diameters (there's always a little). Even with both wheels off the floor, there will be quite some difference in wheel speeds, thus causing the growl to a lesser degree.
Frank
Posted : 08/02/2016 3:06 pm
(@Rob Hesselmann)
Thank you Doug.
I'll look into the wheels.
Rob
Posted : 09/02/2016 11:47 am
(@Rob Hesselmann)
Frank,
I thought that might have something to do with the noise...
Thank you for explaining it for me.
Rob
Posted : 09/02/2016 11:49 am
(@Rob Hesselmann)
Doug,
Nothing shows up in a search for "classic wheel".
Is it an online store?
Rob
Posted : 09/02/2016 12:01 pm
(@m-patterson56)
Rob,
I sorta abbr. that explanation. The differential side gears (the ones that the axle splines engage) are also straight-cut bevel gears (maybe not the correct terminology). The meshing of those with the spider gears is what generates the racket. Imagine an old movie with lots of 30s vintage cars in it, starting off from a stop. First and second howl (isn't that a great sound!?) due to the spur type gears in #1 & #2 but third is direct and passes through no gear reduction so it's quiet. There.....more than you wanted to know. Just don't ask me what time it is. I don't have time to tell you how to make a watch.
F
Posted : 09/02/2016 12:40 pm
(@dlm31)
Noble Member Registered
Try Coker. I believe they have them too.
Posted : 09/02/2016 2:30 pm
(@jomoali)
Frank,
My 28 Packard makes great "howls" in 1st and 2nd gear. Music to the ears!
Per
Posted : 10/02/2016 9:10 am
(@m-patterson56)
Per,
To mine as well! [i]And[/i].....not much need for thrust bearings.
F
Posted : 10/02/2016 10:36 am
(@radio-dave)
The howl of a Essex box in 2nd has to be heard to be believed - magnified by the quietness of top (3rd) gear..
Dave
Posted : 10/02/2016 10:57 am
(@Rob Hesselmann)
Thanks all,
My 22 Hupmobile open touring car made a pretty whine...
And the Model A, and the...
Those were fun cars. The Hudson though, is fantastic!
Rob
Posted : 10/02/2016 11:57 am
(@holden)
Honorable Member Registered
[quote="Rob Hesselmann " post=15427]Thanks all,
Rob
Yep. I've had the privilege of driving some very special cars before, and with just a couple of exceptions that were comparable, none of them were a Hudson. But then again, I AM biased.
Posted : 11/02/2016 6:27 am
Page 2 / 2
