I have a 1954 Wasp (four door) and the stainless(?) trim molding around one of the rear door windows was recently damaged. Is it worth having it repaired by a professional shop? or just try to find donor replacement?
photo is rotated, sorry.
I am sure someone in the club may have an extra one, not sure but that may be the same from 1948 to 1954. There are many 4 door parts cars around. Depending on where you live there may be one close by.
I can help get you one if thats what you want.
I'm parting out a 54 Hornet 4 dr. I will see if I still have the window trim I removed. What door trim are you needing?
Lee O'Dell
Driver side, rear door.
Thanks!
Driver side, rear door. If you could help source one I would appreciate it!
Thanks!
Got it. Do you care if you get on that had holes drilled for ventshades or not?
Hmm, well mine has ventshades, but I don't think they are drilled in?
If it had the origional Auto Ventshades then it was drilled. OK so at least I know what I can send. Please call me 704 792 9110. Lance
Hi Lance, I just left you a voicemail. My car has the ventshades with holes but the moldings were not drilled, looks like someone added them later with some sort of glue,
