http://s294.photobucket.com/user/studebaker2/library/Larry%20Burkes%201953%20Hornet%20Sedan?sort=3&page=1
This Hornet was painted about 12 years ago. The problem area in the front of the hood and was not repaired/fixed. I drill out the spot welds and take the brace out, blast clean and fix then apply an anti rust coating before welding back in place. Use a galvanize welding coating in the weld sandwich area.
Kerry, Thats the famous Pain In The A$$ area on stepdown hoods. 🙂
Agreed. Most of the parts hoods I've seen are rusted out there. Good job on repairing that one. Had to do the same on the convertible.
Sir, you are doing a beautiful job on your restoration! Hats off to you for all your detailed work, including the taking of pictures and cataloging of your work. Cudos...k
