#1 On Distributor C...
#1 On Distributor Cap ??
6 Users
(@Joseph J Verdecchia)
[b]My #1 On My Cap Is Facing #2 In The Compression Stock , And I Know The Oil Pump Has A One Way Key , Whats Wrong With This Picture.
Please Help Me Here
Thank You
Joe
Harley03joe
P. S. Can Someone Call Me (954)-987-9635
Thank You Joe[/b]
[URL= http://i259.photobucket.com/albums/hh319/Harley03joe/6%20Cyl%20Distributer.jpg%2022.jp g" target="_blank">http://i259.photobucket.com/albums/hh319/Harley03joe/6%20Cyl%20Distributer.jpg%2022.jp g"/> [/IMG][/URL]
Posted : 11/01/2016 11:48 am
(@kevinjets)
Just change the plug wires to start firing order at #2. 1-5-3-6-2-4. Or you can play with the oil pump till you get the gear in the right position. Hudson made a tool to line up the gear on the pump. Walt.
Posted : 11/01/2016 12:03 pm
Walt How Does One Change The Oil Pump Gear To Line Up Right ?
Don't The Pan Have To Come Down To Get To The Oil Pump ??
Thanks
Joe
Posted : 11/01/2016 1:35 pm
 BoJo
(@bojo)
Joseph
Believe me it isn't worth the frustration trying to line up the gear to #1. Follow Walt's instruction. Put #1 wire at #2 distributor post. The engine will run like it is suppose to. Even with the tool it is a pain in the neck. May end up trying multiple times to get it the way you want it. I would not do it again in the car in a million year. I wouldn't care what post it ended up on, that is where I would start wiith #1 wire.
The oil pump is on the right side under the exhaust manifold above oil pan.
Good luck
Lee O'Dell
Posted : 11/01/2016 2:06 pm
OK Lee & Walt Thank You For Your Advice # 2 It Is Then :):)
Joe
Harley03joe
P.S. How Do You Think It Got This Way ???
Posted : 11/01/2016 3:39 pm
 BoJo
(@bojo)
Joe
Either distributor or oil pump was removed or both and neither were not put back by the book. Next time you go to a Hudson meet you might see #1 wire at any one of the six cap posts on different cars. Don't worry about it. Your car will go just as fast with #1 wire on #2 post.
Lee O'Dell
Posted : 11/01/2016 4:07 pm
OK Thank You Lee For The Great Info.
Also A Thank You To Walt For His Info :):)
Tell Me This Lee Who Sells The Points & Condenser ??? Also The Vac Advance ?
Harley03joe
Posted : 11/01/2016 5:33 pm
 BoJo
(@bojo)
Joe
Your are welcome. Glad to be helpful.
I have some vacuum advances. Tomorrow I can check with our chapter store if they have points & condensers in stock.
My email is HETcleescars@yahoo.com. drop the HET. Check with me tomorrow.
Lee O'Dell
Posted : 11/01/2016 7:02 pm
 BoJo
(@bojo)
Joe
sent you a private message. He has the points and condenser.
Lee
Posted : 12/01/2016 5:20 am
Lee Sorry But I Sent My Dist To Lance From Hudson Parts.
Thanks For Your Time In This Matter
Joe
Harley03joe
Posted : 12/01/2016 10:54 am
(@holden)
Honorable Member Registered
[quote="Lee O'Dell" post=14978]Joe
Lee O'Dell
Well, it had better, or I'm gonna switch mine! 😉
Posted : 13/01/2016 8:37 am
Ha Ha Funny Russ
Joe
P. S. Lance At "Hudson Parts" Is A Real Nice Guy To Deal With
Thanks
Posted : 13/01/2016 10:25 am
 BoJo
(@bojo)
Joe
I'm glad you found the parts.
Lee
Posted : 13/01/2016 11:52 am
Thank You Lee Me To
Truth Is I Want To Get Rid Of This Car, It Like A Boat Putting Good Money On Top Of Bad Money
Never Again
Posted : 13/01/2016 4:16 pm
 BoJo
(@bojo)
Joe
I have felt that way at times then I say to myself SELF why should someone else enjoy all the benefits of what I have done. I did the work I deserve the benefit. I hope you get to enjoy it a little after all this work before selling. You deserve it.
Lee O'Dell
Posted : 14/01/2016 7:25 am
Page 1 / 2
