Guys
We just put in an 8 volt battery in our Jetliner. W eare concerned about too much voltage on the Overdrive solenoid and perhaps the points as well. any experience with these things ?
Preston Stevens
Moved to the "Hudson" forum category
[quote="Preston Stevens" post=14623]Guys
We just put in an 8 volt battery in our Jetliner. W eare concerned about too much voltage on the Overdrive solenoid and perhaps the points as well. any experience with these things ? Preston, you are right about the voltage. . Your voltage regulator has to be re set for 8 volts or it fries eventually. Not sure about the other parts.
Preston Stevens
Preston, it should be no problem at all. Just remember to set the voltage regulator higher so it's able to charge that battery. A little over 9v should do it.
And FYI, 8V Battery Chargers are available. They are rather compact. Using one for years now on my '53 SuperWasp.
Thanks Nell,
Where would I buy an 8 V charger?
Presotn
I think Interstate Battery sells them and when I googled there appear to be more offerings today but I got mine in 2006 from BatteryStuff.com, PO Box 1703, Rogue River, Oregon 97537, 1-800-362-5397, Technical Help, 541-582-4521.
http://www.batterystuff.com/battery-chargers/8-volt/?gclid=CjwKEAiAndSzBRDp5P232v-qtHkSJABw-VdtUJHKo2zT9EwhrJigYQZ2dnOqA2vwneoMmQr_y3nbzxoCVA_w_wcB
