inner axle grease s...
inner axle grease seal 48-51
2 Users
 Skag
(@skag)
Does anyone have a useable part number/mfg. for the inner seals on the early Hudson step down rear end? OEM numbers are 166224 or 306710
Thanks
Posted : 14/12/2015 9:08 am
(@kholmes)
Dave, I have a recent-looking National box with two different modern seals that seem to match up with the Hudson "inners." One seal carries number P02099, the other 103747. Neither has a mfr. name. The box "part ID" sticker carries the ID "35X70X8", and the numbers 1.378 x 2.756 x 0.315, the latter appearing to be the dimensions of these seals in inches.. Maybe a helpful parts store guy can find the source with one of these numbers. Good luck!
Posted : 30/12/2015 6:43 am
 Skag
(@skag)
Park,
Thanks for the info. I will add it to my "data base"..
I was able to get the inner seals from NAPA. They use SKF numbers.. inners SKF 13710 , Outers were SKF 17310 and the pinion is SKF 17720. Darned numbers are so close, they can be confusing.
Posted : 30/12/2015 10:23 am
