[size=4]Why is it that my Rear Support Plate does not have a bolt hole to hold the pointer?[/size]
Is that plate from an earlier Step Down? Or later maybe? Surely not '55-'56, as I thought the mounting hole for the starter was different on those engines?
Posted : 12/12/2015 9:13 am
You have a motor plate fro a 48 to 50 262 engine. the pointer started in 1951. Walt.
Posted : 12/12/2015 2:25 pm
Thanks Walt. I thought that might be the case.
Posted : 12/12/2015 3:35 pm
Some support plates have it and some don't. I think the later ones are with, early without. Support plate is for hydramatic only, which started in '51. Stick support plate is completely different.
Posted : 15/12/2015 4:26 pm
