Spring tension for ...
Spring tension for drag link
4 Users
(@Rob Hesselmann)
I'm working on fine tuning the drag link spring tension.
The manual doesn't specify...
I'm reading from other sources, that the tension should be 25%-30%
It is difficult enough to access and turn the plugs, much less run them in and out multiple times to guess at 30%, is there a rough formula; x number of turns in, to get me close?
I can see from adjusting if it is too loose (movement) but once play is removed, how much tighter should they be?
Rob
Posted : 06/12/2015 1:18 am
(@sherbot)
Eminent Member Registered
I usually turn them in all the way and then back out to the next cotter pin hole
Posted : 06/12/2015 4:02 am
(@Rob Hesselmann)
Charles,
Thank you.
Rob
Posted : 06/12/2015 5:36 am
(@m-patterson56)
Rob,
Assuming that the drag link installation is the same for the S/D as it is for the pre S/D cars, the set-up instructions in the earlier books simply says "Plug should be flush with end of drag link......" This is the method I've always used without issue.
Frank
Posted : 06/12/2015 5:46 am
(@kevinjets)
Turn plug in till it stops, then turn out 1/2 turn and grease it good and every 1,000 miles. if not it will wear a flat spot and no adjustment will help. Walt.
Posted : 06/12/2015 7:12 am
(@Rob Hesselmann)
Walt and Frank,
Thank you for the instruction.
When searching for looseness in the system a couple months ago, we found the rear cup for the forward end of the drag link missing...
We installed one. I don't remember seeing any wear, but will pull it apart again to check.
Rob
Posted : 06/12/2015 9:12 am
