Installing A/C in my 1939 112... using a basic kit from Old Air Products contact Paul @ 817-531 2665 ext 122... Old Air Products does not supply a A/C compressor mount bracket... have been in process of design and build of the necessary A/C compressor mount bracket.
A/C compressor mount bracket is now finished... I am running a serpentine belt vs a standard "V "belt, serpentine belt created a clearance issue. I elected to stay with the serpentine belt , due to the width of the belt it was necessary to add a idler pulley to create clearance for the serpentine belt to miss the edge of the frame supports. During Fab & build it was just as easy to build three A/C mount brackets vs just one... so if anyone has questions or interest in this A/C pump mount bracket contact me via this forum or thru my E-mail cmdelairemfg@gmail.com.
Some basic info about the A/C & Alt combo bracket... bracket is made from 1/4 plate steel, parts cut via plasma CNC table, parts are MIG welded and finished in semi gloss black. A/C pump mounts via the two original generator mount points (one additional upper mount was added for stability), mount bracket design holds a GM alternator just above the A/C pump. Mount bracket will be supplied with necessary bolts & brackets, idler pulley available if required per your application. Mount bracket alignment is adjustable by design.
Regards
Charles deLaire
It would be very helpful to post a few pics of the mounting bracket. Besides, we all love pics of our favorite marque!
[quote="Russ Chilton" post=13727]It would be very helpful to post a few pics of the mounting bracket. Besides, we all love pics of our favorite marque!
Absolutely Russ even more so because it's a 112 as well 🙂 So Charles not only pictures of the mounting bracket how about some of the car also
