Exhaust Manifold Cr...
Exhaust Manifold Crack repair - hornet
3 Users
(@Bradley Due)
Is it possible to have welded or repair a crank in a hornet stock single bbl straight 6 manifold? Mine has a 4 inch crack in it, and im trying to get it running again, before i remount it I would like to fix it or decide on another direction. Manifold is off the car and seperated from the single bbl intake. Is it worth trying to repair, should i find a replacement, or just mount the clifford headers I have stashed away and call it good?
Also the little tube that runs up to the carb is broke flush with the manifold as well, and I think the little heater flap is frozen closed.
Posted : 03/08/2015 10:21 am
(@Rob Hesselmann)
Bradley,
I'm not sure of the best way, but mine has been repaired by stitching.
Rob
Posted : 03/08/2015 12:53 pm
(@Bradley Due)
my crack is in the corner of the carb base square. Stitching may be tougher in the corner? thanks for the tip. thats a pretty cool process I never heard of until now. Thank you Google/ youtube!
Posted : 04/08/2015 5:24 am
(@Rob Hesselmann)
Bradley,
I've read up on it a little, but am not the one to ask...
I would think a manifold would be fairly easy to come by since it isn't a twin H.
Jeff Perkins in Indianapolis does manifold repairs. I can't find his contact info but I'm sure someone here has it.
Rob
Posted : 04/08/2015 12:46 pm
(@josh-1938)
If the Motor is a Hornet now is a good time to install at least a 2 bbl Carb Intake. If you mean its a single 2 bbl Carb with a tiny crack and you have the 4 carb mount studs I would put JB Weld on it. The carb base would hold it from opening. Where im picturing the crack isnt a high stress or load bearing point needing welded, but I may be wrong since cant see it.
If want to weld it though take it to a welding shop where they pre heat then slowly cool back down afterward. If decide on using headers suggest having them ceramic coated for longetivity...
Posted : 04/08/2015 2:43 pm
