Recent purchase, 1953 Super Wasp, mostly original. Previous owner had twin H and other linkages WAY off- almost all corrected. Anyway the linkage from the lower block mount throttle relay to the trans- believe the kickdown link appears to be from a LWB car ( or some other brand link- after thinking should be same LWB/SWB as this is independent of WB) and the end was bent into a snail wrap and the pin put through to make it "work" So can anyone offer me a proper short wheelbase linkage as described above? Block mount throttle relay linkage back to trans? Something not creatively engineered?
thanks, Scott K
Posted : 03/06/2015 4:13 pm
