Hi all, I have two questions
I want to remove the steering wheel so it can be put back on to line up straight. The last thing I want to do is damage it. What is the safest method? I do not have any specialised tools for this but could get pulley pullers if that is what is used.
Secondly, the rear fender inserts appear to have had something stapled to the upper lip that goes behind the fender when being installed. What was it that was stapled along this lip?
Thanks in advance
Alistair
Alistair,
You need a wheel puller; pretty easy to find one of those. I think those wheels have two holes to insert the proper size bolt, then use wheel puller to force steering wheel off hub by gently using socket drive to turn the center screw of the wheel puller.
There was a rubber lip on most of those rear wheel covers. I should see if I can get a picture of the rear wheel cover for you.
Thanks Tim - steering wheel is off and will get it all lined up tonight. Really appreciate your help.
