308 Head Bolts
2 Users
(@Raymund Krause)
Quick easy question. I know 1/2 bolts, 3/4 head flanged, 3 inches long, grade 8. What about washers? Only half the head bolts that came off had washers.
Washers?
Size?
If so obviously grade 8.
Thanks all,
Ray
Posted : 12/05/2015 3:11 am
(@holden)
Honorable Member Registered
Only if your engine has had modifications to put on "7X"-styled 1/2" bolts. Stock bolts are 7/16". If they are 1/2", you need extra heavy thick washers which can be gotten from the Maas', who keep them in stock. If your headbolts are 7/16", you can go with a standard 7/16" Grade 8 washer.
Posted : 12/05/2015 5:29 am
(@Raymund Krause)
Hi Russ,
Its a 55-56 engine that came with the 1/2 bolt mod stock. So washers through Maas? Just really dont want to screw this up.... lol.
Thanks
Ray
Posted : 12/05/2015 5:31 am
(@holden)
Yes, sorry. Forgot about the 55-56's. The 1/2" head bolts need a really thick washer to properly hold the head in place. Get them from Russ and Randy Maas. 90 ft.-lbs. when you get them, in stages and in the proper sequence. Very important.
Posted : 12/05/2015 9:09 am
(@Raymund Krause)
Thanks Russ!
Exactly what I needed to hear 🙂
Ray
Posted : 12/05/2015 10:51 am
