OK. It was too late to take the Pacemaker to an exhaust shop as I tried to tackle the job myself.
Boy what an undertaking just to get the one-piece tube out. I ended up cutting it.
I see where the muffler is an addition with a standard for the era clamp.
As I have the local shop bend some tube for me, where else is a good place to joint so I can more easily install it myself?
You should see the 'DOUBLE' pipes in my '53; I didn't put them in and I can't imagine how it was done. Would hate to ever have to take them out !!! No joints except at the header connections ! Not much room in a step-down between the frame rails ~~~
Ed,
Here's where the exhaust joint is on my 1950 Pacemaker. Hope this helps!
John Forkner
Thank you. John. I will double check my pile of pipe. I do not recall a joint in my pipe at the location.
But that is about where I need to have one based on what I am remembering from working on it yesterday.
Thanks John for posting that picture. My pipes were pre-bent and needed too be installed which I did myself along with with the muffler which fits tight at the end. I seem to remember that I had to jack the rear end up so I could get the pipe around the kickup over the rear axle. I had my auto body shop guy weld the collar on to fit the exhaust manifold when he was helping me fit the fenders and hood. I took my car to the local muffler shop and had them put a chrome tip on the end which has worked out great and looks nice. If it helps, I can take some pictures of my exhaust system as well. 1950 Pacemaker Deluxe.
Some may want to see my 'tight-fit' dual pipe system with headers.
[b]NOTE[/b]: descriptions are by each photo.
Photos are here (rather than to insert) >>
https://plus.google.com/photos/101895503406236284856/albums/6126667071906991841?banner=pwa
[quote="Richard Dryman" post=9680]Some may want to see my 'tight-fit' dual pipe system with headers.
[b]NOTE[/b]: descriptions are on the right side of photos.
Just requested permission to view the Google Plus photo album.
