Bumbled Bows
1 Users
(@David Carpenter)
I need your help identifying the proper order of headliner bows in a 53 Hornet sedan (or similar). Unfortunately the PO removed them without marking them and the color markings are long gone. There are stamped numbers on each which may help identify. So, if someone has a set out of a car, please help. The following numbers are stamped on separate bows, usually below a triangular stamping:
20
21
? ( too rusty to read number)
23
24
25
80
Can these numbers be used to put them in proper order?
Dave Carpenter
Posted : 19/09/2014 1:26 pm
(@David Carpenter)
Well, just so everyone knows, the Master Parts Catalog comes through again!. I find that the above numbers are apparently the last two digits of the part numbers given on page 393. The rusted-away number must have been 22. So, if you were gonna go look for me, thank you but I'm good.
Dave Carpenter
Posted : 21/09/2014 1:43 am
