Oil Pan Drain Plug ...
Oil Pan Drain Plug Crush Washer for 308 Engine
6 Users
(@rofishbu)
Trusted Member Registered
What is the recommended crush washer for the oil pan drain plug for a 308 engine?
Posted : 15/07/2014 7:37 am
(@kholmes)
Isn't it a pipe thread plug? No washer used.
Posted : 16/07/2014 12:31 am
(@fisher)
A bit of teflon tape on those threads makes 1 less spot on the garage floor.
Posted : 25/07/2014 1:53 pm
(@gjevne)
Honorable Member Registered
That's what I do with mine.
Posted : 25/07/2014 4:09 pm
(@obermeier)
Teflon is fine for normal plumbing involving water, but not for petro-chemicals. It will eventually go soft.
Posted : 28/07/2014 10:57 am
(@m-patterson56)
The Yellow, thick variety is intended for LPG, oils, Gasoline. etc.. I had some that was made in Aussieland that specifically stated those applications on the label on the spool. I can't assure anyone that all yellow Teflon tape is so rated. You'll need to check for yourself, but it does exist.
F
Posted : 28/07/2014 1:50 pm
(@gjevne)
Teflon tape is fine with oils. It is heat that can cause problems with softening the polymer, or caustic will destroy it.
Posted : 30/07/2014 12:15 pm
