I need a new Shaft Rail Switch for my single lever OD transmission. It is the one that mounts on the the driver's side of transmission . It has only one wire attached to it. Mine functions but leaks terribly due to the internal shaft seal being deteriorated. This switch is only used with VM and DM. (single lever) The part number is 304026 Not to be confused with the Reverse lockout switch which has two wires.It looks similar. For now, I have removed the switch and have a blockoff plate on it to prevent leakage.
Any help would be appreciateed.
Thanks, dave
Dave, might I suggest that you post a photo of the old switch? It is possible that someone who has a large number of Hudson parts for sale, might have this switch but not know what it is. And the part number may no longer be attached to his switch, so this would be the only way he could identify it.
I'll do that Jon and post it where it should be! On the parts wanted list.. Thanks, Dave :blush:
