I'd appreciate some direction on removing the rear seat back. Thank You!
Chief Mac
Moved from "Club & Forum Suggestions and Comments", to "Hudson" forum
Thanks Jon,
Must be some kind of issue with the forum - I posted in the "Hudson" forum.
Chief Mac, First, push the rear seat bottom toward the rear of the car. Then push up on it from the front bottom of the cushion. This should release it from the retaining clips . Once this is done, pull the cushion up and out of the way. Next, locate the bolts that are attaching the rear seat back to the rear bulkhead. These are located below the bottom of the rear seat back underneath the cushion itself. They are used to hold rectangular straps that attach to the cushion frame. After you have detached these bolts, (should be 3-4),push up on the sear seat back to clear it from the retaining clips at the top of the cushion. Once you have cleared them, lift the cushion up and remove.
Thanks Lance,
I saw the bolts and assumed they would have to come out and you verified that. I was concerned there would be hidden bolts that I did not find. The bottom cushion came out fairly easily, just as you described.
Thank You so much
Allen McInnish (Chief Mac)
My pleasure Chief.
