A seal under center...
A seal under center support bearing retaining nut
1 Users
(@David Carpenter)
Hey guys, while replacing the center support bearing on a 53HH driveshaft, I found a small cork o-ring under the retaining nut which I assume is meant to hold grease in the splined shaft. It is perished. Any replacement, or should I just find a rubber oring to get the job done?
Dave C
Posted : 18/05/2014 8:40 am
