What is the recommended sealer for the hydro flywheel to crank flange and converter housing ?
Posted : 20/04/2014 12:22 pm
Go to a NAPA store and get a can of GASGACINCH, COAT THE CRANK AND THE BACK SIDE OF THE FLYWHEEL. Bolt them together, 45 ft pds. the converter housing has a gasket, cost the flywheel, stick the gasket on, then cost the converter and install. Best sealing job you can do. I now have 143,000 miles on mine and still no leaks. Best stuff you can buy. Walt.
Posted : 20/04/2014 4:43 pm
