Stuck Clutch on a 4...
Stuck Clutch on a 41 hudson coupe
1 Users
 cvmc
(@cvmc)
Eminent Member Registered
Hello
I have a 1941 Hudson Coupe with a straight 8 and a standard trany.I bought the car and don't have previous info on the car. I got the engine started and the clutch will not release. I removed the transmission and left the clutch and pressure plate on the flywheel. I looked at the clutch and it looks like it is new or had been replaced before the car was parked. I think this car had a wet clutch but it was dry inside. I added some transmission fluid in the pressure plate thinking that this would fix the problem. I put everything back together but it didn't fix the problem. I know the car sat for a few years before I bought it
anyone know what might be the fix for this problem?
Thanks
Posted : 27/02/2014 11:28 am
